21 - 40 of 40 Posts
I still wonder about the phosphorus being partly the problem because the caked up stuck on stuff is all mostly brown particles. Is this happening at all with just 46 and 20-0-0-24?
Or is just when all 3 products are blended
I did not have any phosphorus in my blend. Just urea and sulphur. Chunks were breaking off today from somewhere in the line big enough to plug at the bottom of the manifolds... only 145 ac left.... please be gentle...
I had spilled a little of the blend on the top of the cart last night. Came back in the morning and it was literally sitting in a puddle of water, and it hasnt rained in 4 days. ( 3mm but better than nothing!)
I think it's just simply high moisture content in the fert that they sold you, moving with augers or sitting still, it's no big deal, but once it gets moving with forced air, it breaks down.
If seeding conditions are dry, there is nothing else it can be, simply moisture.
Wrong.
Its the sulpher, trust me.
Floater
Everyone call their local custom floater and get AMS Fines spread in the fall. You will never deal with this problem again.
I will actually be getting some AMS floated on some stuff(no biosul) in early June. Have checked with multiple retailers in this area(central AB) and never seem to see any available. What part of AB are you from and what kind of quotations have you seen?
We are having the same issue, we'll do 60 acres and the towers are plugging and our 10" load auger on our air tank has about 3/4 of inch of the brown stuff caked on the flighting. How do you get it clean?
Water.
Get a 2' pump, put it in your auger hopper then run your auger as fast as you need to move the water out the end. About 10 minutes should do it.
Towers: I stuffed a 2" hose at the back of the manifold and pumped away. Just run air through it for a bit after you are done to dry it out.
Imgreen I washed my auger out the other night. It took about a half hour of filling the hopper and running it agled up at about 45 degree so the water would turn in there a lot before it got spit out. I can not believe how clean it was when I was done. I also took out the meters and cleaned all the chunks around them. If your auger is bad I Would clean it at the end of the day and let it dry over night. The chunks that let loose as you auger runs are a killer for plugging hoses and boots.
Wrong.
Remember the problem I had with the retail fertilizer dealer adding Canola oil to the blend? The problem went away when I asked for no oil added. Could it be some retails or manufacture add something they didn’t use before? Retailer told me the manufacturer recommended the oil! drylandfarmer is right I’m sure “it’s the sulphur”
Anyone else having issues with sulpher nitrogen Phos blends plugging off thier drill?
We started using our 31-11-0-6 Blend, taken home in March, got 100 acres done and plugged up every hose and distribution tower. We also started plugging the seed tubes that only had 50 lbs per acre going thru them. I have to float this **** on now and buy extra starter fert to go with the seed. It took 6 hours to pull all the hoses off and scrape off the sensors and distribution towers. Not fun work when seeding conditions are almost perfect.
Apparently I’m the only one with these problems according to CPS.
Of course you are the only one Highmarker!! ;) Haven't we all heard that 100 times! I worked for a fertilizer dealer in the early 70s and we used to be able to predict when a rain was coming 2-3 days ahead because the dust from ground up fertilizer on the floor would turn to soaking wet slimy goo all over the floor. I do not remember which bin it was and it was mostly just one type of product. Could have been 21 0 0 24 which would follow the logic that it absorbs moisture from the air, or gets slimy from condensation because it is cold from winter storage. It was weird how the floor of the fertilizer shed would be soaking wet on a warm dry sunny day though. Or was it ammonium nitrate, 34 00 that was good for broadcasting because it dissolved so readily and went into the ground?
Could some of the dust caking issues be related to how the granules are handled? And how far they have traveled along with how many time they have been moved? Example is Black Sea product has lots of fines from moving so much. Even phos from some suppliers has a huge amount of dust which causes caking problems. Some locals have changed suppliers to get away from the excess dust that is usually a problem. Some dealers use a skid steer to move product from storage bin to blender and makes less dust.
For many different reasons and problems encountered over the years I evolved to a system of using NH3 down the point of a 5" Dutch precision paired row opener, phos either with the seed paired row or down the MRB, K and S blend down the MRB away from the seed. The S was usually good but on a wet and damp spring it could cause some caking problems. If there was caking problems it was not with seed, N or P and did not create the huge problems in a whole crop. This system was pretty reliable and saved the floater cost and allowed high rates of all products all at seeding time. I have retired and still have this drill for sale.
I'm almost on the same page with the drill, just NH3 in the fall. No fertilizer dramas this year.
Wow! I feel sorry for all you having S plugging. Must be 20 years since we had such a MESS and quit using AMS. Fines or Elemental S is the only way. Please stop using with Urea blends or if any humidity. Good Luck, and change your ways, life is too short to stress with Sulfur. #1 soil test to be sure you need it.
AMS is a biatch. AMS mixed with Urea is a biatch from he##, with a bad attitude.
Truth, AMS is the worst of the straight products (that’s part of the reason fines are a thing, prills just aren’t as stable), finer product is more reactive as well (surface area). The more complex the blend the more trouble you’ll have with storage as well, 2 product blend is more stable than a 5 product blend. Obviously relative humidity when handling and seeding is a huge factor as well. Dry fert issues make liquid look more appealing all the time...
We are having the same issues this year trying to put down 100n 25n 15 sulphur got 480 acres to go. dunno what to do
I hear you.
Been there done that.
Thankfully I just finished banding my canola ground with the dreaded blend.
Zero issues this time.
Low humidity here in the 30% range and cold temps.
I know when I had flowing issues with that stuff we spread it on and seeded next day with the drill.
I'm not sure I liked that idea much.
Think if I had to do it again I would give a pass with the cultivator and work it in, and then seed it.
Oil Cooler/Blockage Prevention System
Airguard sells our Blockage Prevention System to help with this issue, but it is not always the magic bullet for bad fertilizer. We can usually decrease the Relative Humidity by about 50% and increase the air temp about 10degC. Even with that amount of difference in air temperature we have still experienced nasty fertilizer that will keep building up. That being said installing a Oil Cooler will help lessen the problem, even with really bad fertilizer caking.
Airguard Blockage Prevention System
21 - 40 of 40 Posts
