1 - 1 of 1 Posts
Fall has begun. You know what comes next.
Do you have a home with a driveway that takes a lot of time shoveling every winter? Adding a SNOWSPORT® Snow Plow to your vehicle will let you clear snow from the comfort of your heated cab, saving you hours of labor each season.
SNOWSPORT® Snow Plows use a transmission-activated design. Drive forward and the push frame allows the blade to slide up and down with the terrain. Back up and the blade lies back, skimming over the surface. Drive forward to automatically re-engage the blade.
Our plows are low-maintenance and simple to use. There are no hydraulics or electrical connections to worry about. The aluminum blade is resistant to rust and corrosion.
These plows are turf friendly. The built-in trip edge works great on concrete, brick, blacktop, gravel and grass.
We include a vehicle-specific mount with every SNOWSPORT® HD or LT Plow. Once the mount is installed, you’ll only need a moment to attach the plow and get to work. Removing the plow is just as simple when you want to store your SNOWSPORT® Snow Plow for later.
Our customers have uploaded several great videos to YouTube showing their plows in action.
If a SNOWSPORT® Snow Plow is right for you, order one right now and get free shipping directly to your door. If you have any questions, hit me with a reply.
1 - 1 of 1 Posts
