Hi Everyone,
First time post, have a problem we haven't been able to figure out how to fix. We have a 9610 John Deere Combine with 914 belt pickup header. The belt speed is set to speed up / slow down as the ground speed is changed. This has worked in years past but now the belt speed on the header will only speed up (will not slow down). It doesn't matter whether the pickup is in auto or manual mode, the belts will speed up but won't slow down.
We can manually slow down by turning the bolt controlled by the reel slow down motor (left side of the combine), but once the belts are sped up the motor won't slow it down again. We have changed out motor inside the black box and still no luck.
Any ideas/comments are greatly appreciated.
Thanks.
Thanks.
