41 - 49 of 49 Posts
Apparently they need installed in sets of 8, they just happen to be packaged that way as well. Balance reasons.
Wide bodies tend to have the most wear in the middle.
Do they come with the upgraded hardware kits too like the Redekop's?
The rotor's are perfectly opposing and you could change out sets of 2 forever. Not sure what would be different now. Should be able to go half way across with brand x and the other half brand y.
The rotor's are perfectly opposing and you could change out sets of 2 forever. Not sure what would be different now. Should be able tyo go half way across with brand x and the other half brand y.
No hardware.
Don’t know why my Claas tech suggested 8 at a time.
No hardware.
If you install new ones on the very outside across from each other they want you to put new ones in the same spot on the other side of the rotor. Then it’s balanced front to back side to side
41 - 49 of 49 Posts
