1 - 14 of 14 Posts
Is there any difference between a Maurer bin extension and a Cary? They kinda look the same but seems to be more Maurers out there. Measured a Cary yesterday and it's 18 in. tall......are the Maurers any shorter?
Maurers were a better bin extension than the crary at one time. The Crary is made more like the Maurer now so it doesn't make much difference.
Hey Redhat
Can a guy get the bin extension's off a 2588 as a kit, from caseih then put them on a 2577? I think they hold more than Maurers?
Quote:Here are the links to the specs of both, Crary and Maurer.
http://www.crary.com/bigtop_spec.html?bigtoplinks
http://www.maurermfg.com/EXT_SPECS.HTM
Both have similar dimensions and capacity ratings.
Model...............................Standard...Add..... Total
JD 9650 STS, 9660 STS Std.......250....113.....313
JD 9650 STS, 9660 STS Lg........250....200.....400
JD 9750 STS, 9760 STS Std......300....113......313
JD 9750 STS, 9760 STS Lg........300....200......400
JD 9860 STS Std......................300....113.......313
JD 9860 STS Lg........................300....200.......400
Wonder who the mathematician is at Crary?
Don
G
Don
Yikes, I can run a calculator better than that.
G
Quote:
Quote:Yikes, I can run a calculator better than that.
I'd like to think you wouldn't need a calculator!
Don
It's pretty simple math, and no I don't need a calculator to add 300 to 200. Its funny when i do the math that equates to 500.
Sad note though, apparently they are starting to teach kids in grade 3 to use a calculator, so they don't have to learn how to do math the 'old fashion way'. So I guess some day when all the computers crash were going to be up the creek
One thing about bin extensions, I have used over the years 3 different ones and in no way shape or form can I get the bushels on my combine that they all claim to hold, does anyone else come up short on bushels as well? The combine sits level and with wet corn I can get close but still about 20 bushels short, I moved the alarm up and any more corn and it comes running over, but both combines never total what they should........
Don
Don, I also looked at this with a suspect eye, but Crary is figuring you have to take off Deere's topper and THEN put on their's (Crary's) That where the figures are off. Basically, Crary is selling you a flare extension with tip ups, thus getting 400. Since Deere has a decent topper (for once!) they sell the tip up kit separately. (Coincidentally, so does Maurer, both large and small tip ups.)
I have no idea why the early 9650/60 numbers are screwed up. Looks like someone is a little ham-handed when it comes to typing.
Have you looked into the Bish Bin extensions from Harv's Farm Supply? Those look like they might hold a little more than the others. It looks like they cover a little more of the bin. I should probably know a little more about them. I'm good friends with the owners son and used to help out around there once in a while when I was younger. I used to help prep and paint the extensions and then ship them out.
But we've never had a Bish on our combines. We've got a Maurer on our 9650 with the flip up extensions and it adds about an extra 120 bu. I think Bish claims to add 175 bu. with theirs.
1 - 14 of 14 Posts
