Did some research on here, asked many people questions, drove 300 miles to inspect a machine, bought the machine 3 days later, and had it delivered Saturday about 1:30 and was cutting about 2:30. I have never owned a CaseIH machine, but did lease a 2388 from a farmer friend of mine from Iowa several years ago, so I have ran one previously for our wheat harvest. Had a few problems from the get-go with this machine. Dealer had placed the rotor in neutral when we were inspecting the machine a few days ealier(we manually turned the rotor to check the wear), but the rotor did not get placed back in hi. Took me a while searching in the book, before I found out where to move the lever!(lol) Second problem, my rotor speed wouldnt move from 450! Big problem, as dealer delivering the combine had left, and his cell phone was in and out of reception area for about an hour. He "finally" called me back, told me sometimes while setting over the winter, he has seen the adjusting motor, "wheel" get stuck. I greased everything up I could find in that area, verified the adjusting drive motor was working(It would move the shaft about 1/4 turn both ways). I placed the rotor drive in low gear, had son keep hitting the switch in cab from low to high. After repeating this process in both hi and low range, it finally got freed up and worked properly! WHEW! Thought I had bought a real lemon for a while!
Cut all day Saturday with machine with no problems, also cut most of Sunday without any problems until about 8:00 that evening then the bearing on the engine fan went out! I just finished reading your sticky at the top of this page a little bit ago, and that little item was mentioned, now I know to watch it!) Fan was chewed a bit, and of course no dealers have it, as harvest is long gone from this rain drenched area! We took the old fan to a mechanic at a CaseIH dealership to inspect, and he straightened it out enough, and checked the balance, and he thought it would be ok to run, until we got a new one.(new one should be in today) Anyway, made the repairs, few belts, etc, and was ready to cut again, but rain showers sprouted up to go along with the sprouted wheat!(lol) Just rambling on here about the machine, telling my exploits with my first CaseIH purchase!
I do have one question, the person I had running the machine Sunday, mentioned that when he was into some soft ground(which there is plenty) the 4x4 wouldnt spin the tires. 4x4 is working, but apparantly he thought it should have enough power to spin the tires backing out? He mentioned the could here a "whine" of sorts when he really tried to give it full forward or reverse. He didnt know if there was a relief valve on the hydro or a belt that might be slipping or what? thought I would ask you guys of your opinion. Just dont tell me the hydrostat is about ready to go out?! This is a 1997 model 2188, with about 1900 sep hours on it. 4x4 with 2 speed, dual tires.
thanks,
Jim
thanks,
Jim
