Just wondered if anyone out there has a 1 inch seed tube on there MRB's ? I know they have a large seed kit to increase it to 1.25 inch. Having trouble deciding on blockage so was just curious if bigger tubes are neccessary
Through the midrows?Pretty sure standard size is 1.25" now, you'd have to specifically request smaller hose size. As a side note, I seeded fababeans with mine with no issues. 220 lbs per acre and 4.5 mph.
You don't use the 1/2" X 1/2" screen BG supplies on the hopper?Used to be double 1", now replaced by 1.25". Much better setup for sure! I had one 1.25" partially block this spring (stuff still came out when I checked but those 2 rows are yellow???) Apart from that one time in 2 years I have had no plugging issues. There always seems to be some little lumps in urea.![]()
I do use that screen and it works wonderfully except if you don't have it centered or crowd it the product can run over the edge of it.You don't use the 1/2" X 1/2" screen BG supplies on the hopper?
Some little lumps you say!
That crap they extort for these days will sometimes have 1/2 a shovelful of lumps on a 15 T fill!
I never plugged any lines due to lumps and the fertilizer would have been unusable without that screen.![]()
