Here is an actual test of the Bourgault meter system, bulk delivery and air distribution system.
The first pic: a wet valley showing cart tracks and direction of travel. If you look in the distance you will see a series of 8 flags. far right marks the RH end of drill Far left marks the LH side of drill. There are three flags on the LH side of cart tracks and three flags on RH side of cart tracks. These six flags mark my sample rows.
The second pic: The 8 flags marking the start of the sample site.
Third pic: 14" of row measure showing plant count. (If you look closely you will still see red treated wheat on top the ground from the 3710 disk drill, actual stand loss due to large seed boot not being pointed at the furrow was 12%. I had estimated around 10% earlier.)
Here is the test to determine how uneven Bourgaults bulk distribution system really is. This is a 60' bourgault tool bar with a modified air kit.
The field is 300 acres and this test is done in the middle of the field starting in a wet valley and going at an uphill climb with the LH wing on the slight downward hill slope. I marked three rows on the LH and RH side of cart tracks, This would be one sample row from each secondary manifold, to take plant counts within 14" of that row. I recorded plant counts on a note pad. I then moved the flags 40' down the row and replicated that 10 times. I recorded all plant counts each time I moved the flags. I then added them all together and divided by 10 to get an average. L1 would be LH wing tip R6 would be RH wing tip. Here is the results:
L1: (longest primary on LH side) 40
L2: 42
L3: (shortest primary on LH side) 41.5
R4: (shortest primary on RH side) 40
R5: 42
R6: (longest primary on RH side) 41.5
Yes there is a 5% variable between manifolds but I see nothing related to hose length. LH side of drill (L1-L3) average is 41.16. RH side of drill (R4-R5) average is 41.16. center of drill (L3 and L4) average is 40.75. End wing tip (L1 and R6) average 40.75.
I am very happy with even distribution. In fact center of drill to wing tips is BANG ON!
Here is the particulars: Product in seed row varied from 240lbs-280lbs at this test sight. Seed did not vary, just fertilizer. ground speed 4.2mph. fan speed 5200-5400 rpms.
Conclusion: The original air kit on this drill sucked. I was plugging hoses all the time being plugged with product. This season I looked at the air kit as a fluid system rather than and air velocity system. Think of the plumbing under your kitchen sink. You have a dip in you sink drain called a P-TRAP. This dip causes water to sit in the dip blocking air (sewer gas) from flowing though the lines. Now think of your air kit as your sewer drain and your seed and fertilizer as water, and your fan wind as the sewer gas. If you have a dip in the line it will sit with seed and fertilizer reducing air flow causing less air to flow by and diverting product suspended in airstream to lines that have greater air flow and less resistance. Therefor proving the theory of hose routing and angle of decline having a greater effect than hose length of equal distribution. I do have dimpled primaries and secondary manifold tubes. All hoses on drill are cut as short as F*****G possible, and ran as the crow flies across the drill. When openers are down there are no dips in the lines. If you were to pour a 5 gal bucket of water down the primary manifold it would all run out. Hose plugging is now eliminated.
In my opinion Bourgault is capable of equally distributing product on a 60' toolbar if set up correctly. The bulk metering is simple. And Simple = less down time. I don't think the metering system needs to be overly complex to fix something that is simply working. If you can get accurate results with simplicity, simplicity will win with the farmer that has 14 days to keep it running to get the crop in timely. I am an owner/operator and simply stating what is growing in my field right now. This is my honest opinion, and real test. Believe me if I find something wrong I am not afraid to tell you guys. If you don't believe me read my 3710 review!
