Replacing electric clutchs and they are seized to to the shaft. Removed the outside frame mounting plate with transmissions bolted to them to get room for a puller to fit behind the clutches. Seized very tight anyone have a good trick or tool to remove these.
If you can get a puller on it good heat it up with a torch and use an impact on the puller. Dangerous as hell if it slips off. That's what makes it fun. Once it starts moving don't let go of the trigger and rap that ***** off
On some clutches you can just reuse the part seized to the shaft and just bolt the new clutch up to it. Not sure if that would work or not for you.
