Has anyone set up a bourgault cart to be run with a jd rate controller? If so what have you learned and would you do it again.
i put a jd rate controller on my 5250 and have enjoyed it so far. Also put the jd hydraulic drives on the cart.
I don't have one on an aircart but would like to put one on so looking for info,
Did you have to put the hyd drives on or you just wanted them?
Discussion Starter #3
did just the rate controller then my jd AMS guy said it wouldn’t be hard to put the hydraulic drives on. Found some used one and did that. I like it way better than the old chain and sprocket system that was on it. Am running everything thru the jd4600 processor, it was well worth the time to get the cab cleaned up from the mess of monitors from bourgault.
Do you have any of the wiring diagrams to make the switch over? Or did your AMS guy do it all
