These are the settings from a 76ft, 10" spacing, 7700, 4.7mph. I used them on my 66ft and it worked for me. Make sure to set the time it takes for product to get from meter augers to section control. I believe this is under the Implement icon in the wrench menu under Tanks. There are settings for On-time and Off-time for this here. I set my On time to 1 sec, and Off time to .7sec for all tanks. Here are the settings I have used for timing from section control to shanks (I have 8 runs):
On Time:
1,2,7,8 at 3 seconds
3,6 at 2.5 seconds
4,5 at 2 seconds
Off Time:
1,2,7,8 at 2 seconds
3,6 at 1.5 seconds
4,5 at 1.2 seconds
I also think it is important to have your fans turned set for the crop you are planting this year that has the highest minimum fan speed as I believe higher fan speeds cause product to clear the system faster. If you set your section control up for canola (which would have a low fan speed) and use that same timing for something like peas (which would have a much higher fan speed) I believe you will have misses on your peas as the lines will clear faster, thus affecting the on-off timing. Bourgault doesn't make note of this anywhere, but I believe it should hold true but you can try it for yourself by doing timing at 3500rpm and 5500rpm and see the difference for yourself.
To make it quicker to verify overlap/misses in the field, and not waste a bunch of treated seed, follow this procedure.
1) Turn off all your tanks so meters don't run. Choose a tank with nothing in it or a tank that has fertilizer and turn the rate way down so very little is going out per acre. There is no reason to put any product down the first 2 passes, you just need to run the drill in the ground so you have a visual reference point from which to judge on off timing when you cross it later. You just have to have one product going down (even at a very low rate) to make the X30 think you seeded this area. It will turn green on the screen as you seed.
2) Make 2 side by side passes longer than you think you'll need for this test (as you tend to replicate it and it prevents you from having to do these 2 blank passes again)
3) Lock up MRB's and Shanks with the shutoff valves on the respective valve blocks on the drill. Engaged your tractor remote for drill oil flow to openers. Nothing will actually lower, but it fools master clutch into thinking it has been lowered so it will still engaged meter augers.
4) Turn off any fertilizer tanks and just turn on seed tanks. It also helps to double your seed rate so you can more easily identify the seed laying on top of the ground. There seems to be some straglers that come out of the pipes for quite awhile after clutch shuts off, so this helps to show you where the main seed shutoff/turn on occurs
5) Line your unit up to do a 90 degree pass to the original 2 passes you did with openers in the ground. Get up to the speed you will seed at and hit lower on the opener switch about 60ft from where you will cross over your previously seeded area. The openers won't actually lower, but the X30 will still engage all metering and everything will function as though it is in the ground.
5) Drive about 15-20ft with the drill into your previously seeded ground. Go back and check for overlap/skips. It is much easier to see the broadcast seed on top of the ground than it is to dig all the rows up! It is important to note that you should be looking at your back openers for this Off-Time test! They are the last to cross into the previously seed area. For the On-time test (coming out of a seeded area into an unseeded area) you want to check the front shanks as they are the first to leave the seeded area.
6) Adjust timing accordingly
7) Leaving the opener switch in the Lower position, continue driving in the same line and at your seeding speed. The master clutch icon on the bottom right of your X30 should be green but your section control will keep meter augers off until they get to the unseeded ground. Go about 50ft into your unseeded ground and check your coverage.
8) Repeat at a 45 Degree angle to the first 2 passes with openers in the ground and check coverage
Hope this helps.
