A few times during seeding my X20 would act up. Mainly I couldn't use the touch screen. Pushing buttons, it would beep but not do what it should. Paging between cameras was where it would start. Trying to change rate on right side of menu was another. Cursor wouldn't be where it should be and couldn't push the button. A restart usually cleared problem.
There was also some times the drive box setting would seem way to high, I would drop the rate 1 lb and it would cut in half to where it should be. Example: 77 lbs seed rate was 65, 76 lbs seed rate was 30. 30 was the correct rate. 80 lbs seed rate was 32. strange.
I know neighbor has same issue, he disabled touch screen and is using mouse. I don't want to do that.
Are these monitors repairable, or is there an easy fix?
