Case Magnum 8950:
Sometimes it takes a few turns of the start key before starter motor fires, so I'm thinking starter relay needs replaced.
Can't find it on Case parts web site for sure. I'm thinking it's the one on the firewall of the cab. Right above your hand when you open side panel to check oil.
DIrectly in front of clutch pedal on firewall I believe.
If it clicks but does not turn it's most likely the starter solenoid directly on the starter . Most starters are a nippendenso style with a copper ring and 2 contact points that get worn and or just corroded . They can be sometimes cleaned up but can be replaced . Any starter rebuild place should have the parts .
Discussion Starter #5
Okay, Thx for the replies! (y)
