Broke on of the limks on the 7010's feederhouse chains the other morning. Stalks were damp & tough & thought that was the cause. However, when we went to repair it we noticed that the masterlink had come apart causing one of the 1.2 links to break. Looking at the other master links & 1/2 links several of them had the little "s" clips missing, over 1/2 were either gone or broke off on one end. Combine is an '08 & has about 450 seprator hrs & I believe this is the original chain.
I took over the family farm 39 years ago & this is only the 2nd or 3rd time I have ever had these pins break or come out. Started out with a IH 303 & have owned sevral AF combines . I was wondering if this is a common occurance on the 10 series combines or possibly poor workmanship from the factory.
Amyone else having this problem?
TIA,
boog
I'm having trouble with 9120 jumping cogs on one side and wearing chain out prematurely. This is caused from crop following chain around and going back down feederhouse. Case is working on a solution. If your chain has never run crooked, its probably a result of poor quality chain.
