1 - 9 of 9 Posts
does anybody know if a 50 series or non bullet rotor 60 series john deere combine can be upgraded to bullet rotor, and if so how much does it cost to do so.
any input appreciated
Quote:I know some guys that had it done at dealership. A 9760 upgraded to bullet rotor, I THINK the cost was about $12-15K. That was 2 years ago, and it is a guess. So, yes it can be done.
Yeah that sounds about right for a dealer. I did one earlier this year- rotor around 8 grand and 25 hrs labor. Dealer will try and convince you that only they can do the job cuz of the install tool. I built my own tool in 3 hrs and for about $100 in bulk steel. Yes, a bullet does fit in a 50 series but just changing to bullet elements will get you 80 percent there for a fraction of the cost. Elements can be changed in 3 hrs.
that's more then i expected, all i combine is small grains (canola, barley, wheat, lentils, peas and alfalfa) so maybe i should just wait until 60 series or 70 series are a good price, what do you guys think.
Re: bullet rotor, Loewen parts
Just after sending my earlier response, I saw a comment further down about Loewen not making anymore JD parts. I mentioned in my comment that you can get a conversion done at Loewen, from standard STS rotor to a bullet rotor, and I know they continue to manufacture all JD parts and continue to add more every year. There has been no slow down or change that I am aware of.
i put one in a 9750 last winter, customer ran a field cultivator shovel through it and ended up poking some holes in the rotor and the top covers, so it was all covered by insurance.
that customer runs 2 9750's, both 01's, both chipped, both have 635F heads. couldn't really tell a difference in soybeans, not sure of the bpa, but i would probably call them average so around 35-45.
i agree w/ greentech, you are probably better off just switchin the elements on your rotor, unless you have a lot of mog that is struggling to get through (bullet should help with this), or the rotor is damaged or worn out
1 - 9 of 9 Posts
