The transmission light will be on when you are not moving, there is a pump on the right side that only turns when you are moving or in neutral and the hydo. is forward. Is this a hydro. or var. belt drive speed. The belt will run when the clutch is out and the tran. pump will be working, if that is what you are looking at then have them check the pressure at the sender, if it shows ok then the sender is bad or something with the elec. system..
We're looking at a 6620 with low hours that is in very good shape.
The only issue is the when the engine is at idle, the Transmission Oil light comes on. Once the RPMs are increased the light goes out. The machine runs fine and we were told by the local dealer that this is normal.
Can anyone confirm this? I'd love to hear any comments before we buy a problem.
Thanks
