I am having problems getting full maps and summary yield data from my C2100 to my SMS program.
Anybody else using this combination?
Around $3500 for combine kit. The best part I feel is the moisture sensor, did not think I would like it at first but when the OEM plugs up constantly cutting green stem beans then you have to empty the grain bin then climb in the bin to remove the mog and sensor keeps beeping in cab and the ag leader just keeps reading moisture and cleans out fine. I finally raised the moisture alarm to 50% in the cab and just let it plug. They may actually be the same sensor it is just a better way of testing the crop.I already have an integra in the combine for my GPS however the S67 does not have the agleader sensors. I tried reprocessing data and i get nothing. my settings seam to be correct. think i will find out how much the agleader sensors are and eliminate the C2100
I am having exact same issues. My gut feeling since last year is that the monitor is bad. but i can import the same file into my farmworks software and from what i can tell is all data points are there. I talked to agleader today and the kit for the S67 is around $2300S67 that I had last year had issues of not saving fields and date and stuff when entered. Tried a different display got it all to work but had issues with summary screen not showing up when ending a task. Sometimes it would sometimes it wouldn't. Had higher ups from agco out and they said there was a software issue but they thought it was still recording data fine, well some fields it did and some parts of it it didn't. Fast forward to this year with a different s67 same deal couldn't get summary screen to show anything just 0's. Dealer came out to put software update in screen would just lock up. Went and got a display out of another off the lot that had updated version in and it worked perfectly. Must be issues with the displays. Real frustrating. Just looked into trading for a 68 today and they have a option to get ag leader ready. But.. It's a option you have to pay to get even though they are removing their crap.
