I see that the MF 9500 series now comes with the AGI-4 as standard and uses its ISO steering platform through the C2100 terminal in the cab. Does anybody know if runlines form an X30 are transferrable to the C2100? And if done so form an X30 using RTK, are they in the exact same place when they are used in a C2100 on RTK using the same base station?
Alternatively, is there an option to add a C3000 or X30 as a dedicated steering terminal to a 9500 series machine? This would ensure that the runlines are definitely transferrable and repeatable, and mean the steering screen is always available and viewable, with the downside of an extra screen in the cab. If it is an option, doe sthe resume steer switch on tha armrest still activate the steering?
Discussion Starter #4
Harsh, thanks for the reply. We are already running X30 in other equipment so would probably go with that. Just wanted to make sure if we went that way that it was a simple plug and play with maybe a T harness? Also wanted to know that we were able to use existing steer resume button still? Given that the System 150 was factory fitment when 9500 series was first released I am assuming it would be straight forward to fit an X30 or C2100.
