Best thing for you to do is not look for awhile. It will be fine..
Planted round up ready canola for the first time this year. Have it on two different areas. The first field has been in for almost 2 weeks. Some of the seed is up and other places it doesn't look like anything was planted. Some spots have a small plant here and there but I can't even really see a defined row. I planted about 3/4 to 1 inch deep as recommended by my supplier. Ground was dry when planted then we had .5 inch rain the next day. Ground seemed very hard after the rain. Then about a week later we had another .3 inches and the ground was softer. The other field I planted about 4 days later and 6 miles away looks better. I didn't change a thing on the drill. I only got about 5 lbs. of seed per acre on instead of the 5.5 lbs. Now the weeds are coming and I am so sick to my stomach I don't even know if I should waist the time spraying it. (I will but it sure hurts.) What happened, was the ground too hard, too dry? Do I have any hope left or am I just screwed out of all my money? Any help would be appreciated. Thanks![/QUOTE
]it sounds like the issue with my rr canola
