First year with a Bourgault 7700 air tank that has a 1 year old pdm pro low output metering auger in it. Wondering how accurate these metering augers are with canola and how many times to calibrate it. Going to use a few totes of canola seed this year and very nervous the rate will be applying heavy. No scale on the tank.
Dealer salesman says to fill the tank, prime 5 gallons of canola seed out and then do 2-3 stationary calibrations until the variance is 1-2% between calibrations and then start seeding. No need to calibrate again. Is this the way that 7000 series air tanks get calibrated, just stationary and then seed and they will be accurate?
I am nervous about the above method, but would be exited if it was that accurate. My old 6550 air tank, I would calibrate stationary and then again after seeding 20 acres and the calibration was always different after seeding a few acres. Always seemed to apply 0.2 lbs/ac heavy no matter how many times that I calibrated.
