I need a little more grain handling ability on my little homestead. I have 1 good tandem truck and then 2 junkers which are taking a lot of time and maintenance to keep going. I was hoping to replace those two with a cart of some type.
I was eying one of these J&M gravity wagons. We aren`t loading semis but the wagon could serve multiple purposes. They can be built with split compartment and used a seed tender and they are also classed as farm implement so you can pull it behind a tandem without a A1 license. I don't think they are rated for more than 30-40 mph though. If you did have soft fields you could use these behind a tractor but they have no easy way to offload to a truck unless you can throw a 10`drill fill auger or something in the back. Plus it is very low maintenance.
Don`t see many of these up in canada though.
