1 - 2 of 2 Posts
hi ive got a case 2096 front wheel assist that the clutch wont engage worked fine last year but when baling, hay had wrapped around the drive shaft and ripped off a hydraulic steering hose. after that replaced hose then tractor would drive about 10 feet then kick its self out of gear. now the clutch wont engage at all. of anyone has an idea about what would be wrong that would be great thanks.
First I would try the simple things first. Check your clutch cable, and check your solenoids right behind the battery. I only have a 2wd though so I'm not the most familiar with the FWA models. I've got a service manual that I may be able to send to you if you'd like, I believe it goes through the FWA so it might give you some ideas to check out.
1 - 2 of 2 Posts
