1 - 19 of 19 Posts
My friends have a 2096 case front assist that has been down for 2 years while they search for trans parts that are no longer available . They are told that some of the last 94 series has the same parts . If anyone has any idea where to find parts or a parts tractor it would be greatly appreciated . Thanks in advance for your help .
Have you talked to any machine shop? My cousin is a machinist, and he insists that they can make any gears or shafts including heat treating etc. as required. Just need to see the old one to get measurements.
If no one locally is willing to try, I can track down his number.
Discussion Starter #4
It's a powershift gear and I don't believe it matters if it's front assist . But if you wouldn't mind you could pm me with the serial no and I would give it to them to do the research .
This 2094 is only a 3 speed power shift so I’m guessing it’s an older model. It’s pretty much white with black doors.
Serial number is 10326945
It runs good but has power shift issues, it might not help you much.
If it is a sun shaft that they need, good luck. There is a serial break in the 2096, if it is the earlier one their may be hope, but going to be tough if it is the later serial #. The part has to come from another 2096 as this was the only one with a cummins 5.9 motor. If they have the part may be good to go the route that jvw suggests as if you can even find one, whoever has it is going to want an arm and a leg for it. I paid a healthy ransom for one about 4 years ago out of steinbach manitoba, and at the time it was the only one in north america with the late serial #. (sun gear and sun shaft are one piece btw.)
Double R in steinbach and they charged 2200. Parts that are interchangeable are A182523(Sun reaction gear with plate, C1) is the same part # for late models of the following tractors. (Highest serial #)(after 16260432 etc) 2294, 3294, 2394, 4494, 4694, 4890) Also the planet gear pins.(A168912)
Part # A179099 (Short planet gear)is the same part # for late models of the above listed tractors. (highest serial #)
Part #A168208 (Drum, or Ring gear) is the same part #for late models of the following tractors. (highest serial #) 1896, 2294, 3294.
Discussion Starter #9
Still hoping tsipp works out but any help is most definitely appreciated .
There is also a website called Urparts.com where you can make parts requests online. A couple years ago I was doing a very rare Komatsu crawler motor from the early 70's. Of course the turbo was completely finished and I went for a long time searching for this part worldwide to the best of my ability. After almost throwing in the towel I tried this website and to my surprise some guy from florida responded in about three days I think. Let me just say I was very skeptical, however I guess down in the amazon jungle or somewhere they still use these machines and some outfit, (he wouldn't tell me if it was china) was manufacturing brand new replacement turbo's. I think it was around 1700 US, waaay cheaper than Komatsu themselves who couldn't supply the part, so as skeptical as I was I visa'd the fella the money and held my breath. A week later a brand spanking new turbo showed up and low and behold it was the right one. After the project had almost stalled it turned out good. Ive never had to use it for ag parts though...YET. Just thought I would mention it though as it reaches all kinds of people all over that sometimes a person can't find.
Also may be able to help a bit if I knew the serial # of the 2096 in need and which gears it is they need...
Discussion Starter #11
TSIPP's offer is greatly appreciated but is not in the sn range needed . They are currently looking into the salvage ones albertabuck had supplied but are interested in any and all leads . Once again thank you all for your help . I will let you know if we have a BINGO .
Just sat down here for a minute and for shits and giggles did a google search of your part number and a fair amount of hits come up, I would imagine someone has already done this but if not someone should. Pulled this one up and looking at the pictures, unfortunately thats not something that can be easily created in a machine shop. but it lists it as being used in other tractors besides the 2096, those other three models would add to the possibilities. For reference to those who don't open the link, they are 1896, 2294 and 3294 within certain serial numbers. Keep in mind not all staff at a wrecker will know all possible crossovers, so one might have to ask specifically about each possibility.
Just for the heck of it I kept clicking and it did take me to checkout, not sure if thats a sign they actually have one or not but maybe worth a try...
https://www.tractorpartsasap.com/planetary-ring-gear-used-case-a168208-497862.html
The part they need is A168208
Monroe TractorMonroe Tractor
Agriculture
Construction
Parts
Service
About
Contact
PART DETAILS
CASE CORPORATION A168208 GEAR
Part Number: A168208
Description: GEAR
Search Description: GEAR
Manufacturer: CASE CORPORATION
Price: $2,740.00
Reserve This Part
My Parts Manager: Nick Nichols
Phone: 518-785-8013
Search of that part# got this,worth a try to call and find out if it’s actually there
Discussion Starter #18
Wow thanks guys I will pass these on . I guess it will be a monday thing now .
Discussion Starter #19
So as harvest was very trying this got put on hold . None of the suppliers that had it listed had it but after following some leads from them we thought we had a bingo and got it shipped only to find it was mislabled and from the wrong year . So we are once again in search mode . So if anyone has any leads it would be greatly appreciated .
1 - 19 of 19 Posts
