1 - 2 of 2 Posts
i have a problem that the feeder stopped working on my 2366 Combine. Feeder relay was getting hot and then the feeder would cut out. Changed the relay and the feeder would work again. Some one suggested that the reverse sensor could be dirty. Cleaned it and worked for about 4 hours. Replaced the sensor then. Still not working. We have checked all the fuses. Found that one earth cable was heating up, Found loose connection and tightened it. If you put direct current on the solenoid it does work, but gives an feeder error on the screen. Switch was replaced. Both control computers were changed with another combine.
Need some more advice. Is there anywhere that I can get a wiring diagram for the combine / Feeder as it seems to be an electrical fault.
Is there any other sensors that work on the feeder system that can cause it to cut out?
1 - 2 of 2 Posts
