1 - 2 of 2 Posts
Had issues initially with starting tractor and put new neutral safety switch and power transmission relays in.
Now tractor starts but cant shift into any gear
No error codes come on dash and no gear is displayed(just 0 )
How can you access solenoids on transmission ?
Any one else had this issue ?
Thanks
Voltage good? Haven't had it happen to us but apparently under 10.5(?) volts it will default to first gear and won't shift...
Solenoids are towards the front of the transmission, I think on the RH side (When facing the front of the tractor.) Look for the stack with a bunch of wires.
1 - 2 of 2 Posts
