Batteries are fully charged. Lights all come on on dash(that's all - no starter motor noise) but there is a clicking sound behind the cab to my right . Would this circuit breaker be bad behind the cab. Is there a neutral safety switch on these tractors that may play up also?
Not sure if 9150 has it but we had a 9350 with the same problem, dad had hook up booster cables backwards and had burnt out the diode. Lots have the diode internal on the alternator but our tractor was external, check the front of the engine just to the left of the alt it will be on a wire running to cab, or else on the left side of engine not sure on yours. Hopefully this helps!
Get a pry bar and try turning the fly wheel just a little. Sometimes if the starter is sitting just right on the fly wheel it'll just click. New starters don't solve the problem either, it's just one of those things.
