Which case heads are same as 974 flex draper ? Case has 1042 2052 2062 bunch of different numbers which are flex? Lookin to put a 30ft on a 2388 Is there more than just 974 that macdon has as a flex?
Do you have air on the 2162?I find that newholland guys experience rather interesting ! heres my demo experience. 8010 05 model runnin 30ft 3020 with full air 3.5 -4.5mph machine would slightly dlug engine load goes from 65-110%constantly. I put on 40ft 2162 i drove 4.5mph engine load constantly at 95-98% stubble was short these were green stem beans runnin at 20%moisture.
None.Which case heads are same as 974 flex draper ?
974 is the version 1.0 of flex drapers, didn't know MD marketed it anywhere else.No a 2062 is the same as a 974.
You have the 2 little white rods to move to lower position , unlock the big locks @ the bottom and adjust your wheels (I believe they should be right off the ground in flex position) I have mine touching the ground abit !!Ran an 09 fd 70 on rigid all last year on an 2010 ch 8120. Shorter pulse crop this year. Planning on trying out flex mode. Any advice? Just unhook two bars and go? Or do you have to adjust draper tension?
Thanks for replies. Bad altitude. Haven't tried flex so no experience. What do you mean by slight z position? Just in flex?
