I have a case IH MX 135 that when I put it into reverse the neutral light flashes and tractor does not move. Tractor does move forward. The seat safety switch has been removed and has the two wires crimped together. Any help would be great.
Thinking it is your reverse solenoid that is your problem, it is located on top of you transmission near the rear of the tractor. Looking from the back it will be one of the 2 soleniods on the left side of the valve block. On top of the valve block it is molded into the block FWD and REV. Before buying one top try I would swap the FWD and REV one to see if the problem follows to the foward.
