1 - 9 of 9 Posts
our 1680 has a bad vibration that goes away when the feeder drive is disengaged. Almost all moving parts have been replaced with new genuine caseih stuff, but the problem persists! The dealer says they all do that but that's not my experience. any comments, ideas?
Do you have a rock trap? Ours does and had the same problem check chains and sprockets for wear. Also the tension arm that the spring pulls on and check for wear, where it rubs against the bracket. It could be out of linecausing the chain to bind.
Good luck
I know it's only a feeder house, that's why it's so frustrating!!!! After thousands spent at my caseih dealer they can't seem to fix it. The chain tension seems ok as per the owners manual. Still looking for help! thanks
remove chain, does rock trap beater turn smooth or bind, i bet ya got a brg going out, or bent shaft on feeder drive top sprocket, bent shaft on rock trap assy, on front drum, bolts missing, or shaft, drum bent, i would pull feeder chain, you will find your problem, scott.
1 - 9 of 9 Posts
