I hooked up to the airdrill this spring and had 2 errors come up "Tank1 Clutch Shorted or Open" and "Tank2 Clutch Shorted or Open" and to top it all off the master clutch has disappeared off of the list of items that are connected to the BUS. Has anyone found any trouble similar to this?
There is also an intermittent error that claims the flexcontrol system voltage is reading low, but I am having a seemingly related issue with the GPS screen loosing power when starting the tractor under load. just as i let the clutch out that is when both monitors through a fit about low power and then never again. The original 2 issues are constant
