Mechanically, yes. And as far as I know, everything is electrically interchangeable except the header height sensors on the header. Height sensors on headers set up for a CX won't work directly on a Case or CR, if I understand correctly, though your dealer should be able to help you fix that as I think it's just a matter of wiring on the POT. The CX uses a different header height system for some reason.
