Have a customer truck in the shop and trying to figure out a no start issue.
Truck cranks like crazy but won't start unless it gets a sniff of ether.
Doesn't matter whether it was running and shut off for only a half second. Always needs ether.
When it is running, it runs fine and it will run all day until shut off.
Getting active injector current faults on all 6 injectors while running.
Cylinder cutout test works fine.
It's a 1992 7LG 3176
All this is leading me to think that the ECM is shot. Which is weird since I can connect to it and it does run.
Have not installed sight glass in fuel system since I don't think it would lose prime that fast. Plus when I pump the primer hand pump it's stiff right away.
I have checked the timing sensor. It is receiving and sending proper voltage during no crank and cranking conditions.
Any other opinions?
Any other opinions?
