book doesn't seem to specific, are there antenna jacks on the right side of the cab ceiling that I can plug into & not have to run a separate antenna wire out of the cab?
so the wire is hooked up between the cab jack & the threaded exterior antenna mount? Is the interior around the ignition switch easily removed to expose the power leads hidden behind it? Thank you!
Thanks guys, but unfortunately they must have forgot to pull the wires through. I even loosened the corner upholstry & speakers & didn't find them . Oh well least there's a power plug by the key & a mounting place. Thanks for the help.
