Alright.. Im at my wits end with this thing... I have a cfx 750 i bought at a rb auction sale. Got everything set up on my tractor (9270cih) Hooked up the power and nothing. I Even borrowed a used one thinking mine was bricked... and still nothing... like they are not getting power? I took a test light and I am getting power in one hole on the cable that comes up from the Battery. I cant see what else can be wrong? Unless that cable is no good?
Assuming you have a steering system in there as well have you correctly hooked the jumper cable in between the battery power cable and the monitor /steering power cable. I’ve hooked it up backwards before and then nothing works.
Discussion Starter #3
No.. I didnt hook up the ezze steer yet... just wanted to see if the monitor would work... Maybe I should do that!!
Discussion Starter #5
Got it all hooked up and double checked... It still wont turn on at all.. I think I might abandon it and check out that new Wheelman Pro system.
