We have a 2188 and find the electric button control for moving the header up and down to be backwards for us. Going from the swather to the combine is confusing and frustrating.
Just wondering about how I can reverse the button on the combine. Is it difficult to switch the wires in the hand control or can the wires be switched somewhere else.
Has anyone done this?
Any hints would be appreciated?
Thanks,
Don
From what i know, you would be better to swap the wires where they connect to the harness at the bottom of the handle. The wires you are looking to swap are #1 and #3. the wire color is white w/ yellow stripe. They may be in a seperate plug along with a red/yellow stripe wire(this one powers the header switch). You will find these connectors in the console.
Not sure which valve runs the header, but I changed the reel fore/aft on our 2388 by switching the solenoids on the valve under the cab. Took maybe 2 min. tops and 1:30 of that was following the hoses back to see which valve it was.
Ben
