If you like to do mechanical stuff changing it is not a big deal, but if you don't it could be difficult. Having a fork lift with a hole in the end of one of the forks makes the whole job alot easier and safer. You just put a clevis on the fork and chain the clevis to the front rotor shaft and you can slide it right out or back in. A specialty rotor will slide right in without any combine mods'. If you want a standard "specialty rotor". You should be able to find used or reconditioned ones all over. I think Worthington Ag Parts has both. The other option is an AFX "specialty rotor". It has the auger like flighting on the front of the rotor and in my experience really boosts productivity. I was very happy when I switched to the afx. Although the afx does cost some. I don't know for a 60 size, 4 or 5 thousand, something like that, could be wrong. Hope this helps.
