Have you checked that the chopper has all the knives on and checked if it is out of balance. If it is out of balance very much it will throw that rubber out pretty fast. good luck
hello, trying to combine wheat and that little rubber that goes between the bearing and the flange keeps coming out. i changed it once with the kit from case ih went back to the field tried it and the new one came out now, split in the middle. why is it doing this? belt too tight? is there a heavy duty bearing kit? might be better than that little tin flange
thanks for the help, hydro100. there was a knife on one end missing and a bunch of dirt inside the chopper drum
