06 model new to me....was cutting about 3rd day of wheat harvest and notice that the left side of reel is completely leaked down...was not leaking oil, just leaked down itself...tried bleeding air from little screw and messed up rubber washer...2 rubber washers later and still no change...anybody ever had this happen? i just watch it and raise it up ever so often but thats aggrivating. IH tech said it may be the master cyl....that makes no sense to me but im no tech.
Discussion Starter #3
Re: CIH 1020 30ft. slave cyl on reel lift leaks do
ok...i assume you can rebuild these...will check w/ parts counter
been there done it yesterday, what a pain, service manual said master cyl, swapped cylinder same thing, removed hyd line to slave cylinder put hyd pressure gauge on line, would go up to three thousand psi and drop to nothing, lines on this head are inside tube, pulled line out and had a pin hole in line, also did you raise head and have someone hold raise button and bleed, have to have air out of system, scott.
Discussion Starter #5
scott,
seems we have alot of the same trouble...i tried bleeding it...hence the messed up rubber washers...will check for leaks...might just have not got the air out of system...thanks again.
