CIH wants $139 per hydraulic oil filter and my combine needs 2 of them. Will a Baldwin filter($73) meet the specs of my 1680 and allow my hydro to work properly? I use generic filters for a lot of things but I am not sure I should for the hydro.
I don't think they can deny a warranty claim based on filter brand, pretty sure that is illegal. Deere guys are the only ones I ever hear that from though.Since you aren't having to worry about warranty or anything...buy a high quality aftermarket filter and go out for a steak dinner with what you save!
Technically they cant unless they supply them. (Some brands do).I don't think they can deny a warranty claim based on filter brand, pretty sure that is illegal. Deere guys are the only ones I ever hear that from though.
My neighbor had a Mccormik MTX 230 with engine failure due to a faulty air filter made by Donaldson.However they can still try to prove it was the filter and if it is the filter your on the hook.
Have u ever cut a filter open to see if they are the same on the insidesame filter just different color. case dealer that supports sprayers for coop i work sells baldwin filters for hydraulics
Is it a single filter only?My neighbor had a Mccormik MTX 230 with engine failure due to a faulty air filter made by Donaldson.
Donaldson ate the cost of that motor.
I was talking with the parts manager at Straubs and he was at the fleet guard factory when they changed filter brands, he said a horn sounded an the paint guns cleaned them selves, then the filters were coming out painted for deere. He said the filters never changed other then color. Fleet guard also makes a lot of cnh filters. We personal have never had a problem due to a Baldwin filter, and they are 10% of the cost of oem through truck parts and equipment.Have u ever cut a filter open to see if they are the same on the inside
Quality companies like Donaldson often will. Same thing with many engine oils like Delo, no you don't have to pay extra or be apart of a program either.My neighbor had a Mccormik MTX 230 with engine failure due to a faulty air filter made by Donaldson.
