Hi. I've got an issue with the sharpener on our Jag 900. The sharpening mechanism is crashing into itself causing damage. I've added a diagram to try to explain. Basically when the sharpener gets full over to the pawl that winds down the stone, the bolt holding the ram sprocket on is hitting the pawl. AFAICS it should not get that far!
Anyone had this happen?
As the ram travels in the direction of the arrow, the two circled parts come together.
Thanks.
Thanks.
