Heard their is a class 9 gleaner running in North Dakota any body know anything or have any pictures
Just stating the facts. Currently running a r66 and most everything is the same as a '92 r62 only with a bigger unloader and a bigger clean grain elevator with the same clean grain auger. In '92 running 1200bu per hr was good, now we are running the same basic machine with higher hp and running 3500bu per hr. Something is going to break. They need to quit pitching the lightest combine on the market. Just looked up the part number for a clean grain auger for a '92 r62 and my '10 r66 and they are the same part number, it's no wonder why they break.wow I believe someone doesn't like AGCO, why are people so anti AGCO there are problems with them, but I know 2 local guys with brand new deer machines one had the entire shoe come out the back, the other had bearing after bearing go out and found they didn't have grease in the sealed Chinese bearings.
Love that one.How's that quote go...
If its got **** or wheels your going to have problems.
I have been running gleaners my whole life from an F in the '70's to a '10 66 now, they to me are a good simple machine and easy to fix but they need to make their machine bigger and heavier if they are going to survive. You cannot take a r-62 with 225 hp and turn it into a r66 with 350 hp with power bulge and not make the machine bigger. I have gone through at least 1 spindle every year for 10 years and when they break they always put a dent in the tin work above the wheels. You cannot not expect something not to break on these machines without first making them heavier. They have tuned these machines to move a lot of material, better than any other brand but they forgot to rebuild the machine. I have only broken 2 clean grain augers in my time but the clean grain auger needs to be bigger.That's funny, I have been running a N7 to a R72 and pushing them hard for 25 years and have replaced one shaft in all that time and It was due to a manufacturing flaw. Have always had the large hopper extensions and never had a spindle fail, but engines on deere rotary combines have been blowing up all around me for about the last three years. 5 within 20 miles of me. Just stating the facts.
If its got ****, tracks, or tires, I have the tools to fix it.How's that quote go...
Thank you for someone agreeing with me. The 66 will run 3200bph because it is a very well tuned machine and at times it feels low on hp. But I believe the low hp feel is that the machine is maxed out in it's current state. Something is going to break and oh yea what's the deal with now loosing elevator paddles, had to put a new chain in this year and within 50hrs lost a paddle, I have never lost a paddle before this new chain. Dealer says oh yea you have to tighten the paddle bolts after the break in. What? We have not had many chopper problems but we did blow a u-joint this year and no tin work left in the rear discharge. The company has to know where and how to add some iron to these machines but they are so stuck on keeping weight down. Weight is not a problem but lack of weight is.Your not alone greencountry, im also tired of lightweight crap. We run a 12 S77 and have a long list of breakdowns from stuff not heavy enough. Brakes, cleangrain auger,about 2 elevator chains worth of bolts and paddles, yield senser braket at top of elevator 3 times, chaffer broke in half, rotor gearbox failed, rivet pop out on rotor discharge chute. These machines just cant handle high bph without breakdowns, or they can't get to high numbers all together because they wont expand or make it bigger. they need to put some meat in the machine, you wouldn't hear me complain if I had more compacity than I needed or it doesn't break because its built heavier than the minimum required. As far as class 9 they have to show me that they have a class 8, in the field that is, they cant hang with competitive machines in corn.
