Changed my grates and concaves out for corn harvest. When the indicator/pointer on the scale on the side of combine says about 3 1/2, my display on console says 1 1/2. How do I get them to read the same?
thanks,
Jim
u need to zero it out..go ahead and crank the key back and tighten it all the way...u will be able to hear it stop.
then turn off the key...I believe u hold the first top/bottom button on the A post... while holding start the machine and eventually it ill take u threw the header calibration...look in ur book up skips the step and u hit down to change what the little screen shows...it shows 2cyl for how many lift cylinders u have...and u eventually will see concave... select it and that will do what u want....after u do that turn the key off....
look up header calibration in the book.. I used to have that page memmorized.. 126 maybe..
