1 - 2 of 2 Posts
I cut some green soybeans and the lower part of the concave where the wires run through are matted over or plugged.
I was able to take the rectangular side doors off the sides of the combine and clean out the top part of the concave, but any part of the concave that has the wires running through it are plugged.
Will this eventually clean itself out if I combine some corn or will it stay plugged until I pull the feeder house and get in there and do some work on it?
Thanks.
You should be able to take the shields off at the top of the feeder house and clean out your concave by reaching through the rasp bars, unless you have an enclosed cylinder but even then you should be able to clean most of it with the concave open all the way. Maybe try reaching from underneath. There's an access door just above the shoe augers.
1 - 2 of 2 Posts
