Ok we ran our 8010 with a 12 row head in 100 bpa corn this year and 180 bpa corn last year. Here is the settings we used......
3 Round Bars in front
1 Skip wire in the right front
All skip wire after that
4 straight bars
4 set of spiked tooth rasp bars
Concaves at 5-6 last year (4-5) this year
Rotor 420-450 rpm
Left side...... No vanes. They have been removed
Right side.....Vanes from front to just past front 2 modules a little less than half. Vanes over rear 2 modules are full back.(Fast position)
You can put a total of 8 straight bars on the rotor if you need too. We have 4 straight bars on the rear 4 spots. In the front 4 spots we have 8 spiked tooth rasp bars(4 pairs of 2). This will balance it out.
The front concave on the right side is a skip wire. The dealer said that if you run all round bars in high yielding higher moisture corn it will plug there. The skip wire will let more out. The other 3 front ones are round bars, and the back are all skip wires. Also I run the pre sieve at least half way open in corn.
Hope this helps.....
……We run this same setup in beans too. The only change was 4 small wires for wheat.
