1 - 13 of 13 Posts
Hey everyone I am just curious what people with the concord drills are using for ram stops while seeding wheat? Colour wise thanks a lot
There are so many colour combinations and field conditions that what I may use could be so far off the right depth for you. Even tire pressure and side wall depth can influence it as can opener choice. If your new to concords keep in mind that if mud is sticking to the packer tires that’s going to raise the rear up some. Mine had markers on it and being a five section the extra weight hanging on the side would tip the outer section slightly and therefore lift the outer corner of the inner section. Great seeders but need time to fine tune them.
Hate our concord for that reason its absolutely junk, but when come harvest time and crop yields good, i wonder why we own a high maintenance planter lol
I've been learning the Concord way the last few years in wheat, it's a process. Have done a lot of digging up of plants and trying to get the drill to run level. The best and healthiest plants always seem to be 1-1.5" deep so shoot for that. Any deeper and the plants are delayed and struggle to come up, any shallower and the seedbed dries out until I get a rain.
You are supposed to get the center rear section set first since it has no adjustment other than the ram stops and then adjust the rest of the drill to match. If you didn't already know you have to use the same depth stops on all the rams except its important to also note that the wings take an extra stop that is black I believe. The concord is kind of a blunt instrument but can do a good job. I say that because even though I am shooting for 1.5", some seed ends up 3" deep and some barely gets in the ground. I had to force myself to seed shallower than I thought was necessary. Someone told me once if you're not finding seed on the surface you're too deep. I put it in the ground and pray for a rain, that really evens out a stand . Get yourself a nice hand trowel (I have one with inch markings on it) and get used to digging behind the drill.
Should note that all this is for my conditions and yours may vary. Always do some investigating after the crop emerges and take some notes on how the drill is performing and where you need to make adjustments.
https://www.amazon.com/BKID-Strong-Aluminum-Garden-Durable/dp/B07F873XSF
Huge difference with what kind of fall tillage you do. Or when you till in fall, how deep you go. My brother cultivates a lot deeper in fall than I do and we always have to change setting from him to me for the same crop. Only way to know is to do as previous suggestions. Stop and dig.
This is accurate when we switch from fields with different fall work we have to reset machine almost.
Thing we found is when its wet we raise the front by 1 turn, when dry we shim the wheels more and increase packing force
Windmill, what do you mean by shim the wheels more and increase packing force?
Put like a small steel plate inbetween the shank assembly and the frame so it lowers the shovel more so it seeds deeper,
Incresing packing pressure we put more air in the tires go from 10psi up to 40 makes a big difference we found.
Interesting, you're the first person I've heard mention that but it makes sense increasing the pressure. I know the book calls for going low psi to get the tires to flex and shed mud. In my clay soil it seems like I end up with a lot of lumps, I'm gonna try your high psi idea this fall.
When we seed in mud and he packers ball u we lower the psi, but if they hardly pick anything up we make them harder so theynpack the seed better into the soil
One of my gripes with the drill has been the poor seed to soil contact that leads to delayed emergence. Didn't know if it was my depth, soil, openers or packers but it seems to be a combination of all of the above. Have always wondered if there was a better way to pack the seedbed. Sorry if I'm getting off topic from the original post. Like hearing what other hoe drill guys are doing though.
we always had the same issue your having, we replace shovels behind the wheels every 2 years, and put different shovels behind the wheel tracks and set them deeper, and we usually find we seed little deeper than we need to solved our issues.
I hate the drill don't get me wrong, but since we changed those 2 things we've been getting along ok.
we have a planter and the maintenance setting and timing goes into the maintenance of one makes a concord look like a breeze.
Remember that the older Concords came with different packing tires. More of a trailer tire I believe. Those may take different pressure than the actual Titan Packer tires. We usually run ours around 10-12lbs but we have black dirt soil, not the clay. We were running enough acres through our 4010 with 11"? sweeps that we replaced them yearly.
The shanks behind our tractor tires were also shimed deeper. When we went to a Quadtrac I think we actually pulled the shims out. For us just seeding wheat I see no reason to upgrade from a Concord. We did upgrade to an ATX700 mainly because we wanted 60' and 10" spacing but we stayed with the Concord style walking beam packers on it. The bigger ADX3430 cart is definitely a lot nicer with the bigger capacity, but still trying to like the auger setup. Not a big fan of it so far. The meter system also seemed far simpler on the AFS Concord cart we had.
1 - 13 of 13 Posts
