Hi orange, i realise that my comments may not be much use to you because we are in western australia, but I feel i can comment on a couple things. We originally had a TR 87 then TR88 now a TR89. I would not put the 88, 87 in the same category as the 89, the 89 is a much larger header and a very well balanced machine. In our situation the 89 was much closer in capacity to a 98 than an 88. We found the 89 to be a reliable and very simple header (combine to you i guess) and easy to set, when harvesting wheat, barley, lupins and peas the only thing we changed was the rotor speed, fan and sieves stayed the same. On the subject of things to look for, the bracket that holds the top of the feeder house to the main body of the combine cracked and broke on us last year I am guessing this was due to our high speeds and very rough ground more than a real problem with the machine. The other thing about TR's that i found was that the tinwork on elevators and auger seemed to wear out in places like the top of the clean grain elevator and where the doors swing on the bottom of the elvators. I cant think of anythiing else right at the moment but if you want to talk further feel free to pm me.
One final thing i will say is that if you possibly can stay away from the narrow body TR's (87 88 type) they are nowhere near as good as the wide body ones and are a lot harder to work on. All the best with your choice.
Steve
Steve
