I have a client with a CR 9080 working in the field. The Unloading auger is very squeaky when it swings out. Has anyone had this issue?
Discussion Starter · #2 ·
There are no grease nipples located on the pivot, it appears to be a sealed unit. Maybe I will have to pull it off and have a look.
maybe lack of grease on the swivel of the auger??? or in the eyes of the ram?? we have had similar problems with the throat pivots, just not enough grease.
yea i think from memory there is a ring around the swivel, if you could lift it a bit you might be able to get enough in, i am doing a PDI on a CR9080 Elevation at the moment so i will check it out on my one tomorrow
Found problem to be dust getting in the nylon bush of the pivot area. No real fix.
