1 - 2 of 2 Posts
Have cr 940 with 98c 8rn corn head. The head latch hooks do not hook snugly into pins. The hook is too far forward into pin pocket and not making contact with the pin, causing header to separate about 1 inch from feed house at the bottom of feed house front plate when head set all the way down on ground. Is there an adjustment or ? to get hook to hold head snug to bottom of feed house? Thanks
Check the bottom of the head there are bolts that you can slide closer or further away from the feeder house latch. At least thats the way our 99c is hope this helps
1 - 2 of 2 Posts
