Currently running CR970 with Farm/Field/Load Software Update, instantaneous yield readout has been very irregular since this update, crop is consistent, all mechanical setting are OK, know off other CR's in our area doing the same. Any one out there got any ideas on this problem.
We had no trouble with our 970. Are they set up with a mass flow sensor like the JD? maybe it's not mounted properly.
Is it just not working? If your in wet or damp conditions then it might be good to go up in the bin and open the access panel behind the bubble up auger to the sensor and clean it off. Or you can calibrate it. They say you only have to do that once a year and its easy. We had major problems with the moisture and yield sensors and it had the wrong fuse for the moisture sensor which shorted out both.
Take care and let us know,
