Bought this combine at auction last fall and separator clutch refuses to engage the clutch pack? Anyone have a similar problem and any help would be appreciated. The combine had 200 sep hours on it when I bought it. Tech from dealer has put a request on ASIST on Thursday and we are still waiting for a reply back from them.
This is what I do know: (The tech only hooked up the laptop and looked at basic fault codes. Ie. Thresher clutch voltage shows battery voltage of 13.8 when engaged and he has no idea what the Ithresh voltage which toggles on and off at .1 volts for 4 seconds while machine fails to start up means.)
1) Hydraulics running the cleaning fan and chaff spreader attempt to run (ie. turns) until computer decides that the rotor and the rest aren't running. The error code is 61 "thresher speed disengaged" which tells you that rotors aren't turning!
2) The solenoid is activating at block and the internal cartridge that is in the valve block is fully functional. I switched it with the park brake cartridge and I placed the thresher clutch solenoid onto the unloading auger circuit cartridge and it does make the auger start to turn. So all components appear to work electrically.
3) Yes I also have checked the rotor speed sensor and it glows purple and I have tried the rotor in hi-lo and neutral and it shifts appropriately. The rocker bar confirms that all components hooked to the clutch pack when in hi or low do turn!
Any idea of what I need to try next? The peas have been popping like crazy and I have had to bring out the good old reliable non-computerized red machines with lower capacity. I sure hope they can resolve this problem in the next couple of weeks before what cereals we have left can be combined for my brother. I was wiped out by a hail storm on Friday afternoon and I lost everything, peas, durum barley and lentils. Nothing left for me to combine.
